Alright I have spent most of the day trouble shooting this issue. Usually I find a way, but instead I am going to make my first post in the forums. Humbled.
I have a master shape file that contains parcel ID, owner, tax info., etc. I have another file ( access 2003 -open to better file format suggestions-) which contains parcel ID and a "yes" or " no" entry for whether or not the parcel needs a new water meter. All I want to do is add the water meter information into the other shape file. This would create one shape file with one table with all the information that I need.
Ultimately I will use the information to do a map query and find out spatially where i need new water meters.
Right now i have the master shape file connected though the “Connect to Data” feature. I also have the new data added to the drawing though the Data sources------>attach under the “Map Explorer” Task pane. I attached access file (ver. 2003 .mdb) which has two columns “Parcel ID” and “Meter”.
I right click on the shape file under the display manager and select”Create a Join;” however my water meter table is not listed as an option. Will this not work?
Plan B - I tried to Create and connect to the access file as an ODBC connection. Followed this guy’s directions to a T http://www.youtube.com/watch?v=xwk370nnOEI. But when i populate my table under the fdo connection the column headings exist ( “parcel ID” and “Meter”) but the actual data is missing. Am I missing something important?
Thanks for taking time to read this post. Any help or suggestions are appreciated.
Note: I am running c3d 2012 on a Win 7 64 Bit machine. I also removed office 32 bit apps and installed 64 bit apps to see if that would solve the problem. No go.
Hi Thomas,
Actually that is my post and video, that one of 3 videos please take a look at this one it may help on the step that you are missing.
http://www.youtube.com/watch?v=nNGZuQ4k2y8&feature=relmfu
Hope this will help.
Thank you sir. The videos were very informative. Two things to note that were not mentioned in the videos:
1) In access the columns need to have either a text or numeric property applied to them. To do this right click on the table and enter the "Design View." There you can change column "Data Type".
2) In access a primary key must be set. In your video you did this when you import the excel file to access; however, if you neglect to do this you can change or set the primary key under the "Design View" -----.>Design tab in the ribbon ----->tools.
