Civil 3D Forum
Combining 2 cut area surfaces
4 REPLIES 4
612 Views, 4 Replies
Ok, so I have an oddly shapped "cut" area with various elevations that I want to create as a surface so that I can compare the volume with existing survey data. I've been able to get the basic "cut" template in 2 seperate surfaces, but now I want to combine them into 1 surface. When I paste one surface into another, the surfaces go haywire. I have attached a plan and cross section view of what the 2 surfaces (cuts) look like in relation to each other. Does anyone know how I could combine them into one surface and "trim" off the inside grading that overlaps..?
Thanks in advance for your help!
4 REPLIES 4
tcorey
Your section view suggests both cut-outs daylight to elevation 5. If so, you could make a flat surface at elevation 5. Paste the smaller cut-out into that surface and then paste the larger.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
neilyj666
I'd probably find the intersection of the surfaces ( Mindistbetweensurfaces?) and use this to create two boundaries around the surfaces, then create a new surface into which the other two are pasted.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
in reply to: neilyj666
You guys rock. Thank you so much for the replies. Those are both REALLY good suggestions. I went ahead and tried the "minimumdistbetweensurfaces" routine because I've never used it before. After a few trial and errors, I was able to create a polyline at the intersection of the 2 surfaces and then use that polyline to create breaklines, boundaries, remove overlapping triangles and then paste the 2 surfaces together. It looks perfect. Whew! Thanks again 🙂
neilyj666
If this answer solved your problem please mark as solution
All kudos gratefully received
Rail Community
