I have numerous MText paragraphs that I need to combine into a single piece of MText. I want the paragraphs preserved in the final piece. I've found some routines that can combine pieces of MText but I don't know if they preserve the paragraphs.
I have DotSoft Toolpac but it doesn't seem up to the task. Can anyone direct me to a tool or code for this?
Solved by Neilw_05. Go to Solution.
Neil,
The first piece of code HERE worked for me on one triel. Hope it works for you.
Allen Jessup
Allen Jessup
CAD Manager - Designer
ToolPac Mtext Join (command: MTXJOILIN) won't do what you want?
Maybe this will work better?
http://cadtips.cadalyst.com/multiline-text/improved-text-mtext
Randy,
The TOOLPAC tools I have don't work with MTEXT, only DText. The command you mentioned is not recognized in my TOOLPAC.
I tried downloading and running Join Mtext.LSP but it doesn't seem to function properly in ACAD 2004. When I use it to combine 2 pieces of MTEXT it loses all but a few lines of text.
I'm having the same problem with the code in that post Allen. When I join 2 pieces of MText it loses all but a few lines of text.
I wonder if there is something in the code that is not compatible with ACAD 2004.
P.S. I tried running it in 2013 with the same results. Something is wrong with the code.
I tried the 1MT0, 1MT1,1MT2 code in the post you referenced Allen. It does the job so, Kudos to you for that one.
Neil,
I only tried the code once in 2012. It worked as expected there. I'm glad others worked for you.
Allen
Allen Jessup
Running ToolPac 14 here. It must be a new tool.
Copy....Paste....lol. It's got to do with Paragraph formatting. You could write a Lisp pulling code from STRIPMTEXT and TXT2MTXT and come up with something workable. I try to format my mtext paragraphs using tab dilenation. Here is what I do:
1. find/replace the tabs with [tab]
2. set my mtext width to 0
3. explode
4. Add \P to the front of the text lines
5. use TXT2MTXT to rejoin the text.
6. find/replace [tab] with actual tabs.
7. set paragraph setting globally
Actually there is some code in the link Allen posted that does a great job. Look at the code for OneMtext.LSP in the thread.
Mark Green
Working on Civil 3D in Canada
I guess it was a bit vague in the thread. Here is the .LSP I created from the code.
I found the tool in my Toolpac. It was under the MTEXT menu. The command is DSTP_MTJOIN.
I wish I had found it sooner but it's good to have the LISP tool too.
Terry must have renamed it. It's named MtxJoiLin in TP 14
There were about 50 pieces of MTEXT, each being a paragraph in a set of plan notes. If you explode them all and combine using TXT2MTEXT you end up with all the paragraphs consolidated into a single paragraph. That is not a solution.
