Valued Mentor
KirkNoonan
Message 21 of 22 (58 Views)
Re: Color and SHP files
12-10-2012 07:10 AM in reply to: KirkNoonan
If you only want the contour lines to be different colors, then you need to use contours instead of elevations for your analysis. And, to head off the next question, in 'Contours' tab of the surface style, look under contour ranges and make sure that 'Use Color Scheme' is set to true
Active Contributor
M_RR
Message 22 of 22 (57 Views)
12-10-2012 07:14 AM in reply to: M_RR
Oh I figured it out now. Thanks for the help !
