Valued Mentor
43 Kudos
Post 11 of 22
Re: Color and SHP files
12-07-2012 08:54 AM in reply to: KirkNoonan
And you might need to set the elevations display mode in the same place to 'Use Surface Elevation'
Active Contributor
0 Kudos
Post 12 of 22
12-07-2012 08:56 AM in reply to: KirkNoonan
Oh yes, now we're getting close to what I want !! It seems to work ! Am trying this out on my model Monday, I hope it works !! Thanks for your help !
Valued Mentor
36 Kudos
Post 13 of 22
12-07-2012 02:07 PM in reply to: M_RR
You can use banding 3D too if you have that particular style.  Same as 2d banding but is visible in model viewer.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
Active Contributor
0 Kudos
Post 14 of 22
12-10-2012 05:51 AM in reply to: M_RR
Thanks so far, I was able to get the color on on any view perspective !
But I would like to obtain the legend of the color and also to add something like
elevation 0' : color = red
elevation 10 ' : color = blue
etc...
Is this possible ?
Thanks !
Valued Mentor
36 Kudos
Post 15 of 22
12-10-2012 06:06 AM in reply to: M_RR
Yup,
Go to Annotate/Add Tables/Add Surface Legend tables
16 GB RAM
Civil 3D 2012 SP2
Active Contributor
0 Kudos
Post 16 of 22
12-10-2012 06:22 AM in reply to: ericcollins6932
Thanks, I now have the table but it's empty. How do I specify the elevation / colors for my selection ?
I have two object I want to define
The first one is a surface - I can change the color from minor and major in the layer thing, but it does not help me specify the color by elevation ? Any clue ?
The second one is a iso-contours map of a area. I have many polyline, each representing a different elevation. I would like to be able to specify : polyline with elevation between 0 and 10' are red, polyline between 10' and 20' are blue,,and so on.
Thanks !
Valued Mentor
43 Kudos
Post 17 of 22
12-10-2012 06:38 AM in reply to: KirkNoonan
Forget about your polylines. Now that you have a surface, you should use that for all of your analysis and display. If you experiment with the surface styles, you will find that you can make it do pretty much whatever you want. To get the legend to work, right click the surface and select surface properties. Then choose the 'Analysis' tab. On the analysis tab you will see a list of possibilities. Choose elevations, select the number of ranges and hit the arrow that points down. Now, in the bottom window, you can double click on the elevations in the ranges and change them. Those ranges will be reflected in your surface display and legend table.
Active Contributor
0 Kudos
Post 18 of 22
12-10-2012 06:40 AM in reply to: KirkNoonan
Thanks !
Active Contributor
0 Kudos
Post 19 of 22
12-10-2012 06:46 AM in reply to: M_RR
Now that did the trick for the table, but my surface stills does not show color / graded as I specified in the table !
It shows the color I used in the display tabs from the " edit surface style " menu
Active Contributor
0 Kudos
Post 20 of 22
12-10-2012 06:56 AM in reply to: M_RR
Okay so the problem come from the material style. When I use elevation-banding 2-D I get the color I specified in the table. But this is not exactly what I want. I would like something like the contour 5'-25' material but with my range of value in it ? ( I want to line only to change color, not the whole surface, only the iso-contour).
