Hi, i need to come up with a solution for remote teams can work on project along side local workers. We have a centralized server where the C3D Projects are. We work with data references.
What is the best solution for a remote team to work on these files, assuming we don't want to work with 360? VPN to connect directly to the server?
For example, i work out of the office. I connect to the server trough VPN and define my working folder as i normaly would if i was at the office?
What is the downside to this? connection speed? The files vary great in size, we may have a surface file with 150mb or 5mb depending on the size of the project, corridor file usually arround 10mb, the rest is normal dwg, from 1 to 4mb in size.
Tiago Vasconcelos
Hi Tiago,
Your best bet to get this work done will be using VPN. However, VPN has not been fully tested by all teams, and is therefore not technically supported. The main issues that have come up in the past typically have to do with bandwidth and latency speeds.
This article specifies some of the connection issues, and how best to overcome and alleviate them. Check the Soltions area specifically.
