Civil 3D Forum
COGO points
6 REPLIES 6
609 Views, 6 Replies
COGO points
I have points as reference blocks I want to convert them in to autocad points so than to convert them to Cogo points.how to covert block refernc point to autocad points
6 REPLIES 6
Pointdump
Jabir16,
I'm not sure what you mean by "block reference points", but if you mean points from LDD or Softdesk or even Vanilla, you can convert them to COGO Points like this:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
KirkNoonan
If your blocks are inserted with the insertion point at the point location, then the easiest thing would probably to genereate a csv file by means of a data extraction. It is pretty simple - just type 'dataextraction' at the command prompt and follw the instructions. You can then import the csv file int oyour drawing to get C3D points.
tcorey
This code example will ask for a selection set and will place an AutoCAD Point at the insertion coordinates of any block it finds in the selection set. Other objects will be ignored. It does not test for the difference between xreferences and normal blocks, so you might want to avoid picking xref's.
Tim
(vl-load-com)
(prompt "\nPick blocks to convert to AutoCAD Points: ") (setq ss (ssget) len (sslength ss) ctr 0) (while (< ctr len) (setq blk (ssname ss ctr)) (if (= (cdr (assoc 0 (entget blk))) "INSERT") (progn (setq ins (cdr (assoc 10 (entget blk)))) (vl-cmdf "point" ins) );end progn );end if (setq ctr (1+ ctr)) );end while
(setq ss nil blk nil ins nil len nil ctr nil) (princ)
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
troma
Another way:
If all the blocks are the same block:
BEDIT the block, place an acad point at 0, 0 within the block. Save & exit the editor. Now explode all your blocks, and you'll have acad points at each location.
Mark Green
Working on Civil 3D in Canada
in reply to: Pointdump
yes but the problem is to first convert blocks into cogo and then follow the same as you told..
Jay_B
Can you post the drawing or even a portion of the drawing here (that contains some of these blocks) so someone can take a look?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
