Civil 3D Forum
Cogo Points snapping to Z value (Civil 2013)
5 REPLIES 5
jwebb88
2078 Views, 5 Replies
Hi everyone,
Hoping someone will be able to help me out, it 2012, I was able to move Cogo points onto an existing line or polyline, and retain their existing Z value, rather than changing to 0.00 of the height of the poly line/line.
Is there a variable to change this? Thought it might be "OSNAPZ" but thats already set to 1 and this is still happening.
Any ideas?
Jeremy
5 REPLIES 5
Arber83
in reply to: jwebb88
Try to give the dimension polyline  to the desired (Z)
KirkNoonan
Try un-checking this setting in your options. (OSNAPZ = 0)
troma
I think the OSANPZ variable is meant to work with the move command, but not snapping a grip.  I've read elsewhere on these forums that the 2012 behaviour was a 'glitch' as far as AutoDesk is concerned, and 2013 put it back to the way it is 'supposed' to be.
Mark Green
Working on Civil 3D in Canada
SurveyorLee
It is a setting in your point style. On the 3-D tab, set it to Flatten To Elevation and set your elevation to 0.
You will have to do this for each style, or go to the "over rides" for the point Group "ALL'
Surveyor Lee
Adriano_cad
hello
If you drag the point by Grip to a new position to coordinate z will switch to the indicated position, but if you use the Move with OSNAPZ = 1, the quota will be existing at the point.
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
some text
Rail Community
