Active Contributor
jwebb88
Message 1 of 6 (692 Views)
Cogo Points snapping to Z value (Civil 2013)
692 Views, 5 Replies
02-01-2013 12:05 AM
Hi everyone,
Hoping someone will be able to help me out, it 2012, I was able to move Cogo points onto an existing line or polyline, and retain their existing Z value, rather than changing to 0.00 of the height of the poly line/line.
Is there a variable to change this? Thought it might be "OSNAPZ" but thats already set to 1 and this is still happening.
Any ideas?
Jeremy
New Member
Arber83
Message 2 of 6 (684 Views)
Re: Cogo Points snapping to Z value (Civil 2013)
02-01-2013 04:38 AM in reply to: jwebb88
Try to give the dimension polyline  to the desired (Z)
Valued Mentor
KirkNoonan
Message 3 of 6 (675 Views)
02-01-2013 06:15 AM in reply to: jwebb88
Try un-checking this setting in your options. (OSNAPZ = 0)
troma
Message 4 of 6 (661 Views)
02-01-2013 07:04 AM in reply to: jwebb88
I think the OSANPZ variable is meant to work with the move command, but not snapping a grip.  I've read elsewhere on these forums that the 2012 behaviour was a 'glitch' as far as AutoDesk is concerned, and 2013 put it back to the way it is 'supposed' to be.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Distinguished Contributor
SurveyorLee
Message 5 of 6 (643 Views)
02-01-2013 03:58 PM in reply to: jwebb88
It is a setting in your point style. On the 3-D tab, set it to Flatten To Elevation and set your elevation to 0.
You will have to do this for each style, or go to the "over rides" for the point Group "ALL'
Surveyor Lee
Adriano_cad
Message 6 of 6 (628 Views)
02-02-2013 07:11 AM in reply to: jwebb88
hello
If you drag the point by Grip to a new position to coordinate z will switch to the indicated position, but if you use the Move with OSNAPZ = 1, the quota will be existing at the point.
Adriano Oliveira
MaxiCAD Informática
www.maxicad.com.br
