I'm not finding where to change the default Description for Creating Cogo points by the Create Points-Alignments>At Alignment Geometry method
The last characters PC, PT RP etc. seem to be controlled by the Drawing Settings>Abbreviations but the Alignment name and stationing is what I'd like to eliminate from the description if possible.
Almost seems hard coded but hopefully I've been looking in the wrong places.
The descriptions are coming in like the caption whether I select Raw or Full description option.
In command settings for Point>Create Points>Points Creation>Prompt for descriptions>Automatic - Object is what I'm using.
What I'm hoping to accomplish is just PC, PT RP etc for description without the find / replace edits I'm currently doing in the exported ascii files.
Solved by sboon. Go to Solution.
I couldn't see an obvious way to change the Raw description being generated by the software, but I was able to create a Description Format that parses the parameters to show the Full Description the way I wanted it.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
