Civil 3D Forum
COGO points duplicating along crown of corridor
5 REPLIES 5
wilsonm2000
846 Views, 5 Replies
Hi guys
I have created COGO points from my corridor, there seems to be 2 sets of points ontop of each other along the crown of the road.  They are different numbers, so its not the same point twice, anyone know why it would do this?
Martin
5 REPLIES 5
AllenJessup
in reply to: wilsonm2000
I don't know. Are they at the same elevation?
Allen
Allen Jessup
CAD Manager - Designer
chd4trichard
You're probably generating points for multiple codes at centerline, such as pave1, pave 2, subgrade, etc...  You can create points from the horizontal and vertical alignments that define the corridor using "Create Points- Alignment- Divide/Measure Alignment" if all you need is finish grade at centerline.
sboon
The lane subassemblies have an option to turn the crown point codes on or off.  If you have this option turned on for both sides of the road then you'll get duplicate featurelines and probably duplicate points created along the crown.  Check your assembly and try turning off the crown option for one side.
Steve
Expert Elite Alumnus
wilsonm2000
in reply to: sboon
Thanks SBoon, thats what the problem was, it was taking both subassemblies points 🙂  thanks so much for this.
cemvde
how to make turn off please i didnt find
please clear me.
Rail Community
