Member
cwrightbbvpc
Message 1 of 6 (785 Views)
cogo points do not convert when exporting to autocad
785 Views, 5 Replies
01-09-2012 02:00 PM
Working in 2012 dwg. When I export to autocad 2010, only one cogo point is converted to a block and shows up in the drawing.
New Member
jzivoder
Message 2 of 6 (750 Views)
Re: cogo points do not convert when exporting to autocad
01-12-2012 07:56 AM in reply to: cwrightbbvpc
Yes, I am having the same issue.  Using Civil 2010, exporting to ACAD 2007.  It worked for me one time, where it converted all cogo points to blocks.  99 other times it is converting either just one point, or none at all.  The one time it did work, I do not recall doing anything different.
New Member
jzivoder
Message 3 of 6 (743 Views)
01-12-2012 08:19 AM in reply to: jzivoder
Ok, well its not an official fix by any means, but before I exported the drawing, I did and audit and a purge command (didn't actually purge anything), then saved it. It worked..
AllenJessup
Message 4 of 6 (738 Views)
01-12-2012 08:55 AM in reply to: cwrightbbvpc
Another option would be to do it manually before the export. On the ribbon under points it's Create Blocks from COGO Points. On the command line it's _AeccConvertPointsToSdskPoints. This creates point blocks without replacing the Civil 3D points.
Allen
Member
cwrightbbvpc
Message 5 of 6 (730 Views)
01-12-2012 09:41 AM in reply to: cwrightbbvpc
The issue with that is we use point styles and point labels to show the necessary information in the drawing such as symbols and elevations. The procedure that seems to work all the time is wblocking the dwg, exploding the features and then exporting to an earlier version.  Can anyone tell me if this would create a problem down the road?
LeafRiders
Message 6 of 6 (557 Views)
10-25-2012 09:17 AM in reply to: cwrightbbvpc
Creating a block from COGO point command doesn't work as it should. It should take the exact point style and label style and create a block that is named. On this end I get some random looking block with point number, description and elevation with nothing but a node showing for the point itself.
I find that I need to explode all cogo points to create blocks (with a U# block name). Copy all and save to a new drawing.
