curious about cogo points. How do i set them at elevation zero. Having problems drawing dashed lines from node to node. I was thinking that you could place the points at "zero" but the attribute in the cogo point would still hold the correct elevation. Thanks
Solved by ToddRogers-WPM. Go to Solution.
You shouldn't need to, I suspect you are trying to draw a line or 3dpolyline both of which can have differing start/end elevations.
If you draw a Polyline then this will retain the elevation of the first point selected and generate the dash linetype correctly.
Alternatively you can detail a featureline which simmilarly generates the lineetype correctly or convert the 3dpolyline to a 2d polyline.
M
If you wanted them at 0, you will have to alter your point styles. On the 3D Geometry tab, you can set it to Flatten Points to Elevation = 0.
If Setting variable OSNAPZ is set to 1, your lines will be drawn at the current "Elevation" value rather than inhereiting the snapped point value.
