Civil 3D Forum
cogo points at elevation zero?
4 REPLIES 4
MKH-VB
1417 Views, 4 Replies
curious about cogo points. How do i set them at elevation zero. Having problems drawing dashed lines from node to node. I was thinking that you could place the points at "zero" but the attribute in the cogo point would still hold the correct elevation. Thanks
mkh
4 REPLIES 4
MikeEvansUK
in reply to: MKH-VB
You shouldn't need to, I suspect you are trying to draw a line or 3dpolyline both of which can have differing start/end elevations.
If you draw a Polyline then this will retain the elevation of the first point selected and generate the dash linetype correctly.
Alternatively you can detail a featureline which simmilarly generates the lineetype correctly or convert the 3dpolyline to a 2d polyline.
M
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
ToddRogers-WPM
in reply to: MKH-VB
If you wanted them at 0, you will have to alter your point styles.  On the 3D Geometry tab, you can set it to Flatten Points to Elevation = 0.
Todd Rogers
Jay_B
in reply to: MKH-VB
If Setting variable OSNAPZ is set to 1, your lines will be drawn at the current "Elevation" value rather than inhereiting the snapped point value.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
MKH-VB
in reply to: ToddRogers-WPM
that's what I was looking for....thanks very much
mkh
Rail Community
