Civil 3D Forum
COGO Point Renumbering does not work
6 REPLIES 6
ceethreedee.com
899 Views, 6 Replies
Is this fixed in 2015
Not sure if this is fixed in 2015.
if I select cogo points with points number 45,46,47 in that order.. It will prompt me to either (overwrite or <next>)
but neither of these options work..
So the only way to do it is to select in the reverse order and it works.. however this is very time consuming if I have 200 points!!!!!! Can it not just start the renumbering from the highest number?
full post here
http://ceethreedee.com/bugs/cogo-point-renumbering-does-not-work-unless-selected-from-individually-h...
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
6 REPLIES 6
Pointdump
in reply to: ceethreedee.com
B,
I don't quite understand exactly what you're trying to do. Will this help?:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/The-Holy-Grail-of-C3D-Renumbering-Points/m-p/...
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
I'd move the numbers to a larger range and then move them back to where you want. That way you don't get the renumber errors.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Yrah thats pretty much the only way to deal with it. Just annoying that its a three step process instead of one, that could be quickly be fixed with some basic programming! Rant complete... 😛
Infraworks 2021.1,
ceethreedee.com
wfberry
Assuming all points to be renumbered are in the same group.
1. (in the panorama)  Ctrl-A, Datum inquiry, 2000.
First step about 3 seconds.
Bill
ceethreedee.com
in reply to: wfberry
wfberry
not catching you there? how is changing the elevation of my points going to help me renumber.??
Infraworks 2021.1,
ceethreedee.com
wfberry
Perhaps we need to replace Datum with Renumber.
Bill
Rail Community
