Civil 3D Forum
Cogo Point properties window description format is forced lower case text
3 REPLIES 3
IanMcClain
510 Views, 3 Replies
Just switched to 2012 from 2010. When I try to edit the description format field in the properties window of a selected cogo point, I can't type in caps, it's all lower case. If I right click and edit the point, I can use capital letters, however. Anyone else seen this or know how to fix it?
Ian McClain
3 REPLIES 3
tcorey
in reply to: IanMcClain
I'm getting the same results in 2012(sp2.1), but it works in 2013(sp1).
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
mathewkol
If you restart it should fix it. I'm sure sure what triggers this but it comes and goes for me.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
cyberflow
in reply to: mathewkol
@mathewkol Yup that solution works
Should be about time that Autodesk fixes this
Using : Autodesk Civil 3D 2022& 2023
AKA Frank Freitas, Senior Roadway Designer @ Kiewit
Rail Community
