I've created an assembly in SAC and imported to C3D. I've created a corridor with several regions some of which use the SAC assembly and some which do not.
The P codes (P2 P3 P6 and P7) have been imported into the code set style Lightweight 3D View (p_codes.jpg) but when I want to create featurelines they are not showing up (no_pcoded.jpg)
I'm making a basic error somwhere but can't see what it is...any help appreciated
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
I knew it was something obvious - when I swapped my SAC assembly to replace the original one I forgot to reset the targets
It's working as expected now
