Another styles problem.
Have created a bunch of cross sections, of a road, with three layers.
When I edit the code set style shape, or featurelines, nothing happens. All I want to do is change the colour of the outliens and the hatch. Its changed the colours in the subassemblies, nut not the cross sections. Have redone the sections after changing the code set styles, to no avail.
Perhaps this is not a dynamic function?
Can anyone point me in the direction of some documentation on the matter?
Has anyone written a manual for CIV3D yet that contains all of these little issues that you spend vast amounts of valuable work time trying to solve.
I've changed the code set styles in several places, all of which tell me that they are changed and updated - ie changed in the Settings Tab, changed vie clicking on x-sections etc etc etc.
Any help greatly appreciated!
Solved by Joe-Bouza. Go to Solution.
when you edit the code set style are you certain you have adjusted the "View" (upper left corner od the style editor) to be "Section"?
Your Name
LOL
@DAVID wrote:Lord have mercy!
You are right on the money! 🙂
I swear this software is going to put me into therapy.
Thanks Joe!
Yeah these code set styles are a bear to wrap your mind around. But once you get the hang of 'em, they're not TOO bad (still room for improvement though).
Don Ireland
Engineering Design Technician
Your Name
