I make a code set style by doubling the "all codes" style. Then make styles of links points and shapes in which i turn off the visibility in model. I also leave the render materials in links.
I try the set with 3d orbit. But as i turn around the model the rendering materials start to uglify
I attach an image to better understand what i am saying.
When i turn on the visibility of links the problem solved.
Why this happens. Is there any solution to this?
Thank you?
no one knows why this happen?
You might try toggling some of the options in the "3dconfig" dialog.
It appears to me to be a video card issue vs something within Civil 3d.
Hope that helps.
Conan Witzel
i have tried this with two different cards. one nvidia quadro 300M in my laptop and one ati firepro v7800 in my desktop. If i turn on the links everything look fine
