Civil 3D Forum
Close Contour Labels - Issue
4 REPLIES 4
nicholegoodrich16
406 Views, 4 Replies
Hello.  I'm relatively new to C3D (since my new job began in January), so please don't make fun of me if this is a simple question... Smiley Happy
I labeled a few contours by
"Add Labels -> Contour - Single"
My contours are pretty close together at the point I need to have them labeled.  Even though it is a "single" contour, it is showing the label for the contour next to it as well.
Here is an example:
Any help would be much appreciated!
Thank you!
Nichole
4 REPLIES 4
When you select a contour label you should see a short blue line, anything this line crosses is labeled. A single label is just a default length short line whereas a multi label is this same line just stretched at a defined length. So if you shorten this already short line, only the contour you want will be labeled.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Thanks so much! Worked!
Hi I'm having the same problem.  How do you shorten the blue line???
cadtech1986
in reply to: JDESILVA
When you select the contour label, the grip points for the line will be highlighted. Simply drag the grips to shorten the line.
Rail Community
