Civil 3D Forum
Close a feature line?
7 REPLIES 7
Message 1 of 8
ksorsby
7198 Views, 7 Replies
I'm probably being dim or looking too hard, but how do you close an existing feature line? For a polyline you just toggle the 'closed' drop down or type C when editing.
Cheers,
Kevin
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: ksorsby
If it is a single FL It will close itself. Otherwise, use the join command on the modify palette
Joe Bouza
Message 3 of 8
ksorsby
in reply to: Joe-Bouza
Thanks Joe. The join command doesn't appear to close them unless you draw a 3d poly in between the ends yourself and join them to that, or am I doing it wrong?
With a couple of hundred of non-closed features in my drawing, I was hoping to avoid having to draw the lines and join the ends up manually. This is a function that polylines have already - draw 3 edges of a square, C for close and it closes the end for you.
Is this another function that has been bizarrely missed out? 😉
Kevin
Message 4 of 8
rkmcswain
Kevin
Yea, I know this is old - was there ever an answer that worked for this situation?
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 8
AllenJessup
in reply to: rkmcswain
There's only 2 methods I see and they both involve closed polylines. The first is that if you need a closed Featureline you draw a 3Dpolyline, close it and create a Featureline from it. If you already have a bunch of Featurelines you need to close you'd have to explode them to polylines, close them and then create new Featurelines from them. That would be a problem if they're already part of a Surface or being used as a target.
If you snap to the beginning point while drawing the Featureline the command will end. But you'll end up with n+1 points in the Featurelines. IOW 1 more points than you should have. For a square that would be 5.
Allen
Allen Jessup
CAD Manager - Designer
Message 6 of 8
Joe-Bouza
When I first answered this I did not realize you wanted to close a gap. When I draw another FL betwen the gap and joint it becomes closed.
But this is not helpful with hundreds of gaps. You can explode the FL's >> pedit>> multiple>>> close, and then turn back to FL
Joe Bouza
Message 7 of 8
rkmcswain
Wow. A missing, simple feature that would probably take a C3D programmer 15 minutes to fix add.
Thanks for the confirmation.
Message 8 of 8
joantopo
Draw a polyline (or line) between the first and  the last Vertex.
Use the command: JOINFEATURES and select the polyline.   This command is as a button in the context ribbon if you select the FL.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Rail Community
