I have a two surfaces I need to compare to get volumes from, but on one of the surfaces I need to clip out a road from the surface otherwise it will mess with the volumes.. Ive tried different ways such as data clip but that doesnt do what I want it to do.. So I pretty much want to make a hole in the surface..
Solved by civilspace. Go to Solution.
Have you tried adding a boundary to the surface, set the type to Hide.
