Anyone else having this problem? It worked fine until the update. Now it's showing EVERYTHING.
Wes Ashworth
Can you please provide more information. Service Pack for 2014 was not released yet. Do you mean Hotfix 1? Can you also give more description or perhaps post a screen shot or drawing where the issue occurs?
Hi
If I understan you then I think am experiencing this problem as well.
When you look in the section editor, things like 3d Solids show up in the section view whether you are cutting a section through them or not.
Attached is a screen shot showing the solids that were modeled using the Bridge Modeller extension showing up in the section view even though the section in question is after the bridge.
This is for Hotfix 1.
Jason
