I have a 2011 Civil 3D. I need help to change ribbon to Classic AutoCAD view.
Please Help!
Jerry Staley
Please Help!
Jerry Staley
There isn't a "classic" workspace in the Civil 3D menu.
You can either change your menu to the AutoCAD menu (Acad.cuix) or follow the tips here to create your own "classic" settings....
http://www.blog.cadnauseam.com/2010/03/25/autocad-2011-putting-things-back-to-normal/
On the Manage tab select CUI interface, add a workspace for acad classic. Select done then reopen the cui (maybe this is not necessary but it worked for me. After you go back in highlight the newly created work space "acad classic" and select customize , on the customize tab scroll down to partial cui files expand acad and select all the items you want. You should now have a classic work space. If you choose tool bars you are going to have to muck around with there posistiion
You may also want to know that menu and toolbar development stoped in 2010. All commands introduced to the product since then should not be in any menu or toolbar.
John Mayo
HI stinton,
You may need to switch your workspaces
1. In command line type WSCURENT
2. then type "2D Drafting & Annotation" (no quotes)
3. Enter
Luckily C3D uses ToolPallets. So I don't think they'll be dropped any time soon. I build custom ToolToolPallets that contain the new commands. That way I have the commands I use most frequently available quickly. I still have the Ribbon collapsed at the top of my screen for object sensitive and other commands.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Resistance is futile.
Everything is futile. "Ashes to Ashes. Dust to Dust." But we might as well enjoy the battle while we're still swinging. Even Locutus had his temporary victory in the end.
Allen
Allen Jessup
Why not just run AutoCAD ? Start> All Programs > Autodesk > AutocAD Civil 3D 2011> AUTOCAD 2011, then change the workspace to AutoCAD Classic.
