AutoCAD Civil 3D General Discussion
Active Member
0 Kudos
Post 11 of 24
Re: Civl 3D Polylines
05-31-2012 08:55 AM in reply to: ctbailey
It would not use the contours to create a surface.
Active Member
0 Kudos
Post 12 of 24
Re: Civil 3D Polylines
05-31-2012 08:56 AM in reply to: shunter62
I have used a work-around.
Active Member
0 Kudos
Post 13 of 24
05-31-2012 09:00 AM in reply to: jmayo
Thank you. He uses SurvCadd, which I used to use also. I think they will all write XML files. I just find Civil 3D to be so much more difficult than either SurvCadd, LDD or even EaglePoint, all of which I have used. I don't see why something that should be straightforward has become so complicated.
Valued Contributor
2 Kudos
Post 14 of 24
Civl 3D Polylines
05-31-2012 10:09 AM in reply to: lex123456
You are correct, Civil 3D does not accept LDD contours as a surface. It's better to ask for the original DTM or build your own surface/contours with the points and any breaklines you can devise. Susan H
*Expert Elite*
245 Kudos
Post 15 of 24
05-31-2012 10:29 AM in reply to: shunter62
Explode aeccontour objects once and polylines will remain.
The best bet is still to get the xml. Look at the time it would have saved the OP. The design could have been in the workings a minute after the files were sent.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Active Member
0 Kudos
Post 16 of 24
05-31-2012 10:57 AM in reply to: shunter62
Can you tell me if there is a way to enter stuff into the profile manually by station and elevation?
Valued Mentor
66 Kudos
Post 17 of 24
05-31-2012 12:20 PM in reply to: lex123456
LDD is just as complicated as C3D.  It's just different.  Until you've figured out that C3D is not LDD or any of those other packages, you will be disappointed.
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
Active Member
0 Kudos
Post 18 of 24
05-31-2012 12:24 PM in reply to: engrtech
Believe me, I have figured out that it isn't like the others. I just don't think I like it.
*Expert Elite*
288 Kudos
Post 19 of 24
06-01-2012 07:59 AM in reply to: lex123456
You can create a design profile by station and elevation using the tabular editor; a button within the design profile toolbar.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Active Member
0 Kudos
Post 20 of 24
06-01-2012 08:14 AM in reply to: mathewk
Good to know. Thank you.
Post to the Community
New Post
