My company are looking into purchasing the Civils3D software as we are looking to expand. We currently use Autodesk Revit for building structures, but when it comes to roads/drainage we still use AutoCAD and a basic drainage design programme. I have a few questions which i am oping somebody could answer:
Any help would be much appreciated.
Craig Larkin
Solved by annw2. Go to Solution.
Solved by kcobabe. Go to Solution.
Solved by colton.determan. Go to Solution.
Solved by troma. Go to Solution.
I like eagle points pinnacle series training videos. There is a yearly subscription cost, but they are well orginized and worth it in my opinion for anyone learning autocad.
Mark Green
Working on Civil 3D in Canada
To expand on 4&5 since other's have helped in the other questions.
You can change the display, but not as easy as in Revit. You actually have to change the style being used. It's not a hard process, but it would be nice if Autodesk would include the visual stuff in MEP, Revit, Plant, etc... where you tell the drawing what it is and it makes the display the same. Sadly, does not exist right now unless you do a layer state 😞 Atleast as far as I know.
Revit and Civil 3D work very well together. However, if you really want to make them play well (i.e. clash detection) I would employee Navisworks as well. If you just need the site in there for design purposes in Revit, pretty simple to do. There are video and blogs all over the net stating how to do this.
