Hellow there:
I would like to know if my Civil3d 2009 software can be installed in a new computer with Window7 Ultimate operating system; and if so, how can I transfer my licence to this new computer.
Thanks.
Benjamin Delgado
Yes, it works just fine on Win 7.
Use the Portable License Utility included with C3D. Here's some infor from the 2009 help file:
Your stand-alone license allows you to run an Autodesk product on a single workstation. However, you can still install your Autodesk product on more than one computer. Without purchasing a separate license for the second installation, you can use the Portable License utility to transfer a license from one workstation to another.
Keep in mind that Autodesk 2009 products are not supported on Windows 7 and have been known to be problematic. Some people have had success getting them to work, however Autodesk's official response is that this is not a supported environment. Good luck!
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14185352
@TravisNave wrote:Keep in mind that Autodesk 2009 products are not supported on Windows 7 and have been known to be problematic.
What problems?
I've used C3D 2009 extensively on Win 7 with no issues discovered, outside of a couple of UAC issues that are easily-fixed without disabling UAC. And of course, the MAPIINSERT issue, where MAPIINSERT doesn't work on 64-bit systems in 2009 (but it also doesn't work with the 3GB switch enabled in XP).
I know Autodesk did not officially test C3D 2009 on Win 7, which is why it is listed as "not supported", but I haven't discovered any issues peculiar to Win 7. Lots and lots of bugs, but those are in the program regardless of the OS.
