Your title says, "civil3d text too small in paper space" which implies the
text in the layout itself..
1. Check the scale of your viewport.
2. Check the size of your text in the style.
If the text is too small, you have to make the text larger in the style.
For instance, if your text is 0.10" tall in the style then that is the size
your text should be when plotted.
Bill
wrote in message news:6268514@discussion.autodesk.com...
It is Civil 3D object text like I mentioned in the title. Station offset
labels, alignment labels, and line and curve bearing labels.
