Civil 3D Forum
Civil3D not for the occasional user....
39 REPLIES 39
Message 1 of 40
paulhoman
1630 Views, 39 Replies
We are a consulting engineering firm that uses AutoCAD and Civil3D.  However, it is necessary for us to use Civil3D only about 5% of the time in our drafting and design work.  This fact has made it an absolute nightmare implementing Civil3D into our work.  Civil3D is an endless labyrinth of windows, drop down menus, pull down menus, dialogue boxes.  And to add to the confusion, they give you half a dozen ways to access anything.  There are countless settings for everything.  And likewise countless locations for these settings.  Autodesk has taken the manipulation of data and settings to an absurd level.  At best, our experience using Civil3D has been excruciating.  In summary, Civil3D was written for users who use all of it's features on a daily basis.  Since we do not use it's features on a daily basis, we really struggle.   Anybody else having a similar experience?
39 REPLIES 39
Message 2 of 40
Joe-Bouza
in reply to: paulhoman
you are right, but the answer is one word ...TEMPLATE.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 3 of 40
MtnMax700
in reply to: Joe-Bouza
As a surveyor using it-I agree.  It has never been great for surveyors anyway.  But I have to agree with Joe.  I complained enought that we brought in an expert for 2 days-not cheap.  He set-up my styles for me and created a template and went over all of my questions about the things I use-which isn't much.  Has made a big difference for me.
David
Message 4 of 40
You are going through this like everyone else has but you are not seeing the forest for the trees.  The more you use anything the better you get.  Practice makes perfect.  You must either use it or not.  Don't pick and choose.  You need to figure out ways to incorporate the tools into your work flow. All of the standard AutoCAD tools are built into Civil 3D.  It is, after all, a "vertical".
You will find once you are comfortable with the tools that you will have users tell you "I will never do it the 'old' way again."  You must remember it is completely different software with a completely different workflow and conceptual base.  You are not drafting with Civil 3D, you are modeling.  Big difference.
We forget that AutoCAD itself has a million different ways to get to every command but you are comfortable enough with it to know your own way and you don't think about it anymore.  For example to draw a line: ribbon, type LINE, type L, click the icon, use the drop down....but you aren't complaining about that.
When you get frustrated with the software and say "it doesn't work"...remember, no offense, but it does work just fine for a good many of us.  It takes time.  There is a learning curve, but it does work.  Yes there are glitches, but find me software that doesn't have any with the more advanced tools.
The key to a good functioning work environment is to have solid templates set up.  This eliminates the need for users to go into the "endless labrynth" to set up styles.  But you will find with time and practice that all those windows are almost exactly the same each time and make sense.
You must embrace the change and make it work for your company just like at one point you did for AutoCAD.  You have a huge resource in these forums, as well as the Civil 3D help and your reseller.  You can make the software work in time.
Personal experience, I can literally do things in minutes that used to take hours or days.  But it took time.  I did not learn to model overnight.  To a point, you are correct that it is not for the occasional user.  But why should it be?  It is multi-thousand dollar software for professionals who need these tools everyday.
Tony Leggieri
Gutschick, Little & Weber, P.A. (GLW)
CADD Manager
Civil 3D 2023.2.1
Windows 10
Message 5 of 40
I appreciate your input.  I wrote my first post out of frustration but i should have given more information.  I have been using AutoCAD since 1985 and Land Desktop since about 1998 so i understand everything you're saying.  Contrary to what you may think i am not afraid to learn new things.  We did have some training in Civil3D which did help.  And i also got help creating the styles i use the most.  And i have experienced the savings in time with a lot of tasks in Civil3D.  Again, i guess i was just speaking out of frustration of the immense learning curve.  We are committed to using Civil3D and i know in the long term it will be immensely better for us.
Message 6 of 40
I hope you did not take offense at anything I said because it was not a personal attack. My rant was out of frustration as well as I deal with users getting annoyed everyday.  I wish Autodesk marketed Civil 3D a little differently and not as a progression from LDD. It is brand new software that functions completely different.  The concepts however are the same and a lot of the routines are infinitely better than it was in LDD (pipe networks and grading objects for instance).
 I do agree with your Post title that it is not for the occasional user.  It can't be. Whenever this topic comes up in our office, my arguement to management is always that someone will do a task in Civil 3D for the first time and then not do it again for 8 months simply because they don't need to.  A road corridor will get designed and then not need to be tweaked or modified for months because of the review process.  Than a year later, the user starts a new job.  That doesn't exactly breed efficiency.
All I know is that, at least for me, Civil 3D works as demonstrated.  But I have been fiddling around with Civil 3D since the beta in 2004.  Thank goodness it has improved over that piece of crap!
Our company went through training and had IMAGINiT (then Avatech) setup our styles for us.  They have routines that can do it quickly for them, which always makes me wonder then why it costs so much but still well worth it.
The other thing with Civil 3D, besides templates is KEEP IT SIMPLE!  Don't overload the model with too much data or you go nuts.  It is designed to be built off your surface, so you may spend more time there but it will save you time in other places.  You will find the balance eventually.  Try and focus on the positive and the time savings and the pain of the learning curve will eventually go away.  And we all know unfortunately that the answer of "it just takes time" will never fly with management who expect immediate results.
Again, use this forum for help.  Use other resources.  There are plenty out there.  Get your users to try and only use 1 method of getting around until they are comfortable (all settings changed from the Toolspace, for example.)  Each user will develop their own style eventually.
And of course, we all feel your pain when the time comes that you have mastered it and love it and Autodesk completely changes it again.
The only constant is change.  It is inevitable.
Tony Leggieri
CADD Manager
Civil 3D 2023.2.1
Windows 10
Message 7 of 40
I did not take offense at anything you said.  And i hope you didn't misunderstand the tone of my response.  I was not trying to be saracastic or portray bitterness.  (Tone can often be misunderstood in here.)  I appreciate you taking the time to write and i will take your advice.  Thanks.
Message 8 of 40
Neilw_05
in reply to: TonyLeggieri3279
In my current position with a small civil engineering consultant firm I've run into strong resistance to embracing new technology. Prior to my coming onboard they were using Land Desktop for their design needs. As they never invested time and resources into learning how to use it they never realized or utilized it's capabilities. Instead they used it to do some basic tasks such as generating EG countours, alignments and profiles and from there they did everything manually, including tweaking the profile and contour graphics without modifying the underlaying databases. As a consequence the models and databases no longer represented the design and thus all the design tools that depend on the models and databases were useless.
Civil design software is model driven. What that means is rather than drawing countours and calculating spot elevations you build models of the terrain and infrastructure and those models drive the graphics and annotation. This model based approach to design can be very efficient since changes to the models are dynamically propogated to the documentation, thus reducing or eliminating hours of tedious manual drafting as well as errors in the documents.
While this model driven paradigm is very powerful it also requires special skills on the part of the design team to use the software to interact with and manipulate the models. Formerly simple tasks such as changing a spot elevation or a slope label now require editing the underlying models. This is a big problem for companies that are unwilling or unable to invest in the technology skills needed to use the software. I liken it to a construction comany that buys GPS guided machinery with automated grading controls but they don't invest in hiring or training operators to use it's capabilities. If they don't know how to use the equipment how can they benefit from it's capabilities? They might find that they can't run it the way they are accustomed to and the owners might conclude that the equipment was a waste of money because they aren't any more efficient than with the old equipment. The fault is not the equipment but their not utilizing it's capabilties.
I am not trying to imply that all companies are guilty of improper implementations. Commiting to the model driven paradigm presents many problems. There is a large investment of time in setting up and building the initial models and the users are constrained by limitations and deficiencies in the functionality of the software for example.
Perhaps an ideal solution would be some sort of hybrid paradigm where graphics can both drive and respond to the models.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 9 of 40
Sinc
As I've said often before, I agree...  C3D's UI is unnecessarily complicated, and very confusing.  My personal opinion is that anyone who has a strong understanding of Civil Engineering and/or Surveying should be able to use this software with a minimal amount of training.  If that's not true, then that's a problem with the UI design of the software.
I understand that SOME training is necessary...  Getting used to model-based design is a paradigm shift for many users, and there's a cost involved in that.  But if you understand Civil Engineering, and can get used to the idea of model-based design, it should be EASY to adopt the software.  But given all that, there are many instances where C3D's UI is very non-intuitive, and even antagonistic for the user.  Those things really need to be corrected.  (And yes, I'm about to start on my Project Rant again, so I'll stop before I get into that...)
All things considered, though, I tend to be roughly 5x as productive now with C3D (as a Land Surveyor, also using my custom software that I've since offered for sale as the Sincpac-C3D add-on), compared to our previous heavily-customized Land Desktop system.  That's based on long-term staffing requirements, of office staff vs. field staff over a period of years.  It is NOT some estimate based on some biased "shoot-out", or anything like that.  Net result, based on the number of people we need to hire over the long term, we find C3D to be a huge improvement over LDD.  It still leaves a lot to be desired, but as with most things, C3D is a "work in progress"...  It's not mature yet, but it's still really powerful.
Sinc
Message 10 of 40
markmcguire3467
I'm still not a fan of the ribbon but perhaps the microsoft world drove that shift...  i fear the day they remove the ability to load the menu...  +1 on the productivity but the learning curve is too steep and the options are overkill.  interesting recently, we worked on a design build proposal and i was told to keep my effort simple but the software is geared towards the model...  hard to build a 35% model.  i just said "let me design the whole thing - making the sheet set will only take a few days after that as we have our styles in place...  big difference from the land desktop days...
Message 11 of 40
antoniovinci
Sorry, Paul, but.. why did you buy Civil???
If I'd want to fly, I would buy a Cessna, not a Jumbo Jet.
Or, if I have money to buy a Jumbo Jet, I should try its features for a while (i.e. 30 day Civil's free trial version)...
Edited by
Discussion_Admin
Message 12 of 40
neilyj666
Not sure that Civil 3D is the right program for you if you are only using it 5% of the time - seems to me that it will be greatly underused. However if you start using it more frequently you'll probably not want to use vanilla AutoCAD.....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 13 of 40
_Hathaway
in reply to: antoniovinci
So now, since you bought a Jumbo (not fitting your needs) there's no room to complain, sir.
I seriously doubt that Paul had anything to do with the purchasing of software his company. Most end users don't.  It's typically upper management that does this and in the case of Civil3d being treated like a step up from LDD...when in fact it is an entirely new piece of software.  End users understand this while most people in charge of actually purchasing it do not.  Sure, there are the exceptions to the rule but I am speaking in general terms.
We felt Paul's pain too when we started and still experience occassinal growing pains when trying something new or different with the software.  All in all it is significantly better than LDD once you get past the initial learning curve.  There are still some baffling issues like why we can't create a simple closure report based on a legal description.
Message 14 of 40
paulhoman
in reply to: _Hathaway
Civil3D was purchased for us by upper management because it is the industry standard.  And despite my complaining, we will manage to learn it.
Edited by
Discussion_Admin
Message 15 of 40
bill
I agree with you.  You can use it as a design tool to develop a roadway model and determine profiles and sections or a grading plan with good earthwork quantities.
In my opinion, It is a really bad drafting tool. Try getting a portion of a vertical curve in...
Message 16 of 40
lsimms1
in reply to: bill
I actually like using it as a drafting tool as well as design.
I have my template with the styles set up and ready for just about any job.
After years of softdesk, ldd, Ep, and microstations it was a difficult transition.  In the past, what you would draw the picture on the screen, and put that information into a database.  Now, you create your database and it gives you the  picture.  Totally different outlook on things.
Message 17 of 40
RainierFan
I agree with everything that you say except "Civil3D was written for users who use all of it's features on a daily basis". I don't know how it was written for. I've been using it extensively for three years and I have concluded it has been financial disaster. I have the unique perspective of being the owner of a civil engineering design firm and a C3D user. In spite of its enormous complexity, it does not come with most of the fundamental subassemblies needed to design a road. It does not come with a basic parts (and sizes) necessary to lay out a simple storm drainage system. I could go on ad infinitum on the subject of deficits that are now obvious to me. On top of that it’s a revenue black hole. It constantly crashes or slows down to where a system cleaning and reboot is necessary.  I probably lose over an hour of production a day on average simplycleaning/rebooting. If I put out a product like this, I would not be in business long. I've been using CAD since 1984 when four seats cost a quarter-million. I know a pig when I see one.  It appears to me that most of those who advocate C3D are either “web celebrities”, trainers, resellers, or C3D book authors, etc. (or have those ambitions).  I would be greatly surprised if a significant number of them remain imtimately connected with the day to day taks of getting drawings out the door.
Message 18 of 40
Joe-Bouza
in reply to: RainierFan
<snip> it does not come with most of the fundamental subassemblies needed to design a road. It does not come with a basic parts (and sizes) necessary to lay out a simple storm drainage system. <snip>
Sorry to hear about your dis-satisfaction. What is a fundamental assembly? My tool palette has loads of stuff OOTB, Plus when I build one I want to use again I can drag it to the TP. As for the part list I don't fret over model structures being too precise and represent in plan with blocks.
I'm not celebrity, author or web guru. Just a schmuck trying to make a living at this and it works for me; I still draft linework the way I did in 1990, but get enough out of the tools to help with the design.
Sorry your production is down. I can see how it can happen, but I still would not give up these tools for LDT
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 19 of 40
RainierFan
@Joe-Bouza wrote:
<snip> As for the part list I don't fret over model structures being too precise and represent in plan with blocks. <snip> My goals are no longer that lofty...I only want decent cross-sections.
<snip> Sorry your production is down. I can see how it can happen, but I still would not give up these tools for LDT <snip>  LDT was ever an option...but InRoads is looking better by the day.  As a manager of a large Civil Engineering department, I hated InRoads cost and set up time...but hey, at least it worked! (now C3D looks like eaual or double the setup overhead).  Check writers just do not want to see staff spending weeks/months setting up a CAD system or project in CAD before decent drawings get spit out.  Recipe for disaster.  And now that I do my own drawings...my perspective really hasn't changed on that issue.
Message 20 of 40
Joe-Bouza
Good Luck
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
