I'm creating a Storm Sewer Design table that I want to dynamically update based on links to key objects within the drawing. Objects like Storm Boundaries, pipe lengths between manholes, pipe slopes, pipe diameters, etc.
If the entities in the dwg. are just AutoCAD entities, I can easily go to my cell, insert Field by Object, select Object. I can then select area, length, etc. The problem comes when I try to do that with Civil3D entities like Parcels, Profiles, Feature Lines, Pipe Network, etc. All I get for options with those are Color, Description, Linetype, etc. and not the important data within those entities.
So my question is how do I access data from Civil3d entities to make it available within a Table?
