Valued Contributor
1 Kudo
Post 1 of 4
Civil3D COGO Point User Defined Property Unable to delete (Dependency)
604 Views, 3 Replies
06-05-2013 06:47 PM
 I created UDP Classification and then created User defined property, for some reason one of the properties under a classification has a dependency and I am unable to delete it.
How do I delete the UPD and the classification.
There is a dependency mark on top of the name "Handle"
Under what circumstances we get that and what all the dependencies.
How do I delete the UDP in this case.
Thanks.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
917 Kudos
Post 2 of 4
Re: Civil3D COGO Point User Defined Property Unable to delete (Dependency)
06-05-2013 07:17 PM in reply to: raghulan
You have to delete the value assigned to any points in the PointGroup(s) you assigned the Classification to. Even after removing a Classification from a PG, it looks like the Point(s) that had values assigned retain those values...I guess in case you decide to re-assign the classification.
Valued Contributor
1 Kudo
Post 3 of 4
06-05-2013 07:29 PM in reply to: Jeff_M
I even tried deleted all points (All Objects) from the drawings still it seems to be the issue.
Will look and try few other things and if I find something, will post..
Thanks for your help.
www.zcodia.com.au
0 Kudos
Post 4 of 4
09-27-2013 09:45 AM in reply to: raghulan
You can also check any point file formats or other commands that may be referencing that property
