Hello all,
First time using a sheet set in 2013 and having a small problem. Using the sheet set manager i cannot open any of my sheets if i already have an open dwg. If i attempt to do so it will flick across to the current open dwg and go to paperspace but will not open the sheet i am wanting. If however i have no dwg open using sheet set manager i can open a sheet no problems. Not really a huge issue as the sheet set data / fields are still dynamic and function properly etc but i have to open each dwg in my SS through file/open etc. 2012 this was no issue so am wondering if there is a setting somewhere in 2013 i have to turn on / off in regards to opening dwgs through SSM.
Cheers,
Josh
