I'm just wondering outloud:
If you already own SQL Server, and you're on subscription, than it seems
you're in an ideal candidate for the Vault (because you'll be able to run
the Vault for AutoCAD as well - sure, the workflow if 'different,' but very
simple). I know you don't WANT to use the Vault, but it just seems to fit.
You'll probably struggle to get the databases to interact with each other,
but then again, maybe separating the Microstation vs. the AutoCAD data isn't
a bad thing. I'm just thinking if you already own SQL...
Data Shortcuts are still around, but not as strong. Given the limited
amount of work you do, or need to do with C3D, you may be fine using LandXML
(if you need to) to share data, but again - just seem to be the perfect
candidate for Vault...
MHO,
sm
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
wrote in message news:5258937@discussion.autodesk.com...
Scott,
Our ProjectWise database will reside on a SQL server. Is there a way to
fake to SQL databases to interact with each other?
Adrian Crowfoot, PE
CP&Y
www.cpyi.com
