AutoCAD Civil 3D General Discussion
machadt
Message 11 of 16 (7,028 Views)
Re: Civil Imperial Subassemblies not working
02-06-2013 02:58 PM in reply to: tcorey
You are missing one of our default paths there, is should be the first one on top.
C:\Users\YOUR_USER_NAME\appdata\roaming\autodesk\c3d 2013\enu\support
Please add it and let me know if this work for you.
Tatiana Machado
AEC-ENI Application Engineer
mauserp08
Message 12 of 16 (7,022 Views)
02-07-2013 06:44 AM in reply to: mauserp08
Tatiana,
The path was there but was located towards the bottom of the list. I moved it to the top but it did not help. The toolbars still will not work and do not show any thing other than what I posted earlier. I did get a fatal error when I tried to select anything on the Assemblies - Metric or Assemblies Imperial. I have included an image of the fatal error for you to look at. I have tried to select other portions of those two tabs and each will give me a new error code. Any ideas?
Sid.
mauserp08
Message 13 of 16 (7,019 Views)
02-07-2013 07:01 AM in reply to: tcorey
Tim,
I have talked to my boss and it looks like I will be doing the unistall and reinstall soon. I have a lot of parts that I created for my pressure pipe library that I need to copy out before I do so. I did post a fatal error message to Tatiana. Any ideas on what is happening there? Thanks.
Sid.
machadt
Message 14 of 16 (7,016 Views)
02-07-2013 07:33 AM in reply to: mauserp08
Sid,
Try to reset your user setting before doing a clean install, here is the link for this procedures just in case:
Resetting user setting:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19170578&linkID=9240697
Clean install of C3D:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20304823&linkID=9240697&CMP=OTC-RSS...
Tatiana Machado
*Expert Elite*
tcorey
Message 15 of 16 (7,013 Views)
02-07-2013 08:08 AM in reply to: mauserp08
mauserp08 wrote:
...Any ideas on what is happening there? Thanks.
Sid.
Hello Sid,
It could be caused by several different things. Without sitting at your system, I wouldn't be able to tell you why it's happening.
I have done it myself many times: You're so intent on knowing why you have an error that you spend hours on it over several days. A reset of the software is often the most expedient way to get you back to work.
Tatiana is right, you should try resetting the user first. That takes seconds. If that doesn't fix it, try a repair install, that takes a minute or two. Doesn't work? Do the clean uninstall, re-install. That can take an hour, depending on your setup source and status of your realtime virus scanning.
Best regards,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
mauserp08
Message 16 of 16 (7,009 Views)
02-07-2013 01:00 PM in reply to: machadt
Tatiana,
Well I went through all the steps outlined by you and it took a clean install to get everything working. So far everything looks to be running like it should and I am able to build assemblies. Now to get my personal settings set up and I am off and running.
Tim,
You were right about spending hours and days trying to figure out a problem. To be honest when I first discovered this I spent a little time on it before I posted here. This one was way above my head. See, this old dog can learn a new trick or two.
I want to thank both of you for your help in resolving this issue. It is much appreciated and I could not have done it without your help.
Thanks.
Sid.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
