Hans Moller said the following On 4/22/2007 11:00 PM:
> How many menu items do you have? I once noticed there is a limit of 24 menu items, you can add more in the CUI settings, they will however simply not appear on the menu. You may find if you move the tools menu item higher up the list, another one will drop off.
There is a limit of 24, but that's only a limit of what is saved between
sessions. You can make as many as you want display at any given time.
See attached image.
R.K. McSwain
http://rkmcswain.blogspot.com
