Civil 3D Forum
Civil 3D Volumes dashboard, sort columns alphabetically?
71 REPLIES 71
Message 1 of 72
wilsonm2000
7009 Views, 71 Replies
Hi
Is there a way I can sort the columns in the dashboard alphabetically?  Normally you just click the title in these windows to toggle the way it sorts it, but you cannot do that with this tool.  Its making my cut/fill report look messy, as the surface volumes are not in any order.
MArtin
71 REPLIES 71
Message 2 of 72
neilyj666
in reply to: wilsonm2000
No can do with this tool as it is at the moment
Either need to make sure you pick the boundaries in the required order or create xml file and paste to excel and do the sorting there
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 72
wilsonm2000
in reply to: neilyj666
Ok, thanks anyway :o)
Message 4 of 72
How has this not been fixed yet? Still can't sort alphabetacally on Civil 2015.
And even if you pick the boundaries in a specific order Civil sometimes messes up the order.
Message 5 of 72
neilyj666
I agree it's a major PITA but I'd guess it's just not a big priority for Autodesk as it isn't anything to do with 360/Cloud based products
Message 6 of 72
tcorey
You're so cynical. 😉
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 7 of 72
neilyj666
in reply to: tcorey
LOL 🙂
Message 8 of 72
Have there been any improvements on this topic?
Message 9 of 72
neilyj666
None - refer to post 5....;)
Message 10 of 72
Well that's too bad... i mean, who wants to show anything now a days in a random order.
I'm no expert but i'm pretty sure sorting is a basic concept in highschool programming classes..
Message 11 of 72
Just bringing this topic back to the top in the hopes that someone at Autodesk notices........
Message 12 of 72
neilyj666
Refer to post 5 - if they can't make a wizzy marketing video then everything else is at the bottom of the pile. They seem to forget that people need to produce quantities at the end of the day from which to get a build cost and these quantities are the basis of everything else.
It's quite fun trying to find how many "irritations" are still present in 2017 with no sign of a fix or improvement
Message 13 of 72
I'm still on 2014, so I can't help with your 2017 list.....
Message 14 of 72
Plopper
Has this been added yet using 2016 and still cant find a way to sort the volumes in the dashboard.
Would be nice for simplicity when viewing and nice when exporting.
Message 15 of 72
neilyj666
in reply to: Plopper
Refer to all previous posts in this thread........
Message 16 of 72
autoMick
With 2016, even the pick order doesn't necessarily dictate the display order - which I find infuriating. The only reliable method to get the order you need is to generate the report and copy or import to Excel, then sort there.
Cheers
- Mick
Civil3d user in Australia since 2012.
Message 17 of 72
Udo_Huebner
in reply to: autoMick
No Ideas for the Dashboard, but what's about sorting the report?
A small change/add to Line 53 in
C:\ProgramData\Autodesk\C3D 2017\enu\Data\Cut Fill Report\CutFillReport.xsl
<xsl:for-each select="AeccCutFillReport/VolumeSummary/Volume">
<xsl:sort select="@name"/>
<tr style="HEIGHT:30px">
will sort the CUT/FILL Report.
Udo
Gruß Udo Hübner (CAD-Huebner)
Message 18 of 72
TTamburri
in reply to: Udo_Huebner
Thanks, good Tip I am using it right now.
However i do agree that this is something that should be added in.
Message 19 of 72
CyrusLSteele
ALL HAIL KING OF CIVIL3D
Seriously with one line of code you just fixed something we've been irritated by for years. You'd think someone at Autodesk would've thought of doing this themselves instead of leaving it to the community.
Message 20 of 72
jcushing
I did as you recommended and the xml report that is generated is fine. However, if I select to insert cut/fill summary in to the drawing it still shows up in disarray.
Any other recommendations?
Rail Community
