Hi Dana,
Unfortunately, I feel you are wishing for something akin to Israel and
Palestine sending a combined and friendly team to the Olympics.
The crazy things is that LandXML should have been designed and implemented
such that the design data is independent of the Drafting program and thus
all that should matter is that the design can be build from the information
in the Land XML file.
However, I.T. Department intrangience with the need to protect their
fiefdoms, plus the partial implementations of Land XML make the concept
difficult to implement.
We have a similar idiocy here with our Title Approval Authority refusing to
accept plans which are not labelled to their specific length based precision
requirements (and just in case that was easy, the whole layout has to be
adjusted such that it closes with the rounded values.)
We have had to write some fairly serious Civil 3D customisation to label the
parcel segments in accordance with these requirements
Laurie Comerford
CADApps
www.cadapps.com.au
"Dana Breig Probert" wrote in message
news:5244177@discussion.autodesk.com...
Hi Folks
I have had decent success getting Civil 3D dwgs into Microstation with
Inroads.
However, there is always work to be done with hatches, linetypes, text
Here is what I am currently doing:
Export LandXML of entire Civil 3D dwg/project
Export Civil 3D.dwg to Acad.dwg
Cleanup Acad.dwg
Run layer translator that we made (changes NCS layer names into the local
DOT level numbers/colors)
Export through Map>tools>export to .dgn
Open .dgn in InRoads/Microstation
Import LandXML
Then, the Microstation people have, say 85% useable information. But they
need a lot of cleanup
Does anyone have a customization to assist with this?
My goal is that my clients that work with DOTs will be able to do most, if
not all, of their design in C3D. Then, we will have a great way to get
things looking right in Bentley without much pain. They will always want to
open in Microstation for the final prep and check, but I want to make it
easy.
And all of this is just model space- the design in this case is the only
thing that matters (not sheets.layouts, etc)
I will pay in money or fresh vegetables.
Dana Breig Probert
http://civil3drocks.blogspot.com/
CADapult Ltd
Empowering Design With Innovative Solutions
www.cadapult.net
