Does anyone know what is Civil 3D Subassembly Composer ?
Is this individual software or with Civil 3D together?
Thanks.
paya
Solved by doni49. Go to Solution.
Autodesk Subassembly Composer for Autodesk AutoCAD Civil 3D is included as an optional subcomponent available for installation from within the AutoCAD Civil 3D installation wizard. It downloads as a separate program that you open seperately. It creates *.pkt files, which you can upload into Civil 3D for use in creating an assembly.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Kati,
Thank you for the response.
Can you give me more details that how to do the installation? step by step.
I have Civil 3D 2013 & 2014 installed on my computer.
paya
@Anonymous wrote:
Kati,
paya
First look and see if it's already installed. Start>All Programs>Autodesk>Subassembly Composer 2013/2014 (you should see one or both versions listed if they're installed).
Don Ireland
Engineering Design Technician
