It stops immediately.
Yes, I have access to both the installation on my workstation and the
installation image on the server.
Kenn
"Isaac Rodriguez" wrote in message
news:4017ca85$1_1@newsprd01...
> When you say that the file stops running, can you be more specific about
at
> which point it stops. You should see a Windows Installer message saying
that
> an installation is in progress. Does the installation starts and stops in
> the middle of the process, or does it never completely starts?
> According to the help, error 1624 is related to the paths where the
> transform is generated, this is usually your Temp directory, so I don't
> think that is the issue. It might be a permissions issue. Do you have
access
> to the original source of installation of Civil 3D for Civil Series?
> Thanks for reading.
> Isaac Rodriguez
> Software Engineer
> Autodesk, Inc.
> "Belken Engineering" wrote in message
> news:401571de_1@newsprd01...
> > I cannot install the Civil 3D service pack. We have AutoCAD 2004 Civil
> > Series installed and Civil 3D. The install file I am attempting to run
> is:
> > C3D_2004_SP1_UL_Series.exe
> > The file stops running with the attatched error message.
