Civil 3D Forum
Civil 3D Setting
3 REPLIES 3
ParadigmAE
151 Views, 3 Replies
Civil 3D Setting
Good Morning!!
Question: I have been working on creating a .dwt file with custom settings that match my companies desired looks. To make a long story short, I need to know if there is a way to export all my custom settings from my current "Master" .dwt file & import them into another current "project" file.
Just, an FYI, I don't want to have to open a new file from my "Master" .dwt template and copy/paste all the current "project" information into it.
Thanks.
3 REPLIES 3
kcobabe
in reply to: ParadigmAE
Either way you will need to paste one or the other into the other. If you want the master in the current open the dwt saveas a dwg and insert it into the current drawing (make sure you explode on insert).
Software wise you can get EEpropack and they have a tool that does this.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
I thought only styles came in with the insert, not
the settings.
Bill
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Either
drawing (make sure you explode on insert). Software wise you can get EEpropack
That is correct, hence the reason we built a tool to handle as many of
these settings as are available via the API.
James Wedding, P.E.
Engineered Efficiency, Inc.
Rail Community
