Hi all,
I am currently working on Civil 3D 2010 to design a highway. I would like to use the plan production with my drawing template (.dwt) containing the plan and profile viewport to produce mulitple drawings. Creating View Frames seems to work fine, however it is not creating the sheets to the desired format, ie style, data, viewport scale.
The Problem/s
Hope this is understandable being my first post and all.
James
Welcome to the Forums!
Do you have custom drawing templates set up all necessary styles etc. styles which are all supposed to work
together and have worked on other projects in your organization?
First we need to try to understand why things aren't matching up.
Hi Jay,
The drawing template I created was customised from the the Civil 3D (Metric) Plan and Profile.dwt which is a standard document. All I did to "customise" this was to move the title block along the bottom and change the size and shape of the viewports.
I have never used these on other drawings or project, and as a company do not have any standardised drawing template.
The viewport in the drawing template should only display the style settings which I have defined in the Model.
Any other information please let me know.
James
Hi Jeff,
Yes, that seems to be a nice work around for the vertical height, but does not solve the problem on the horizontal scale/size. I have tried placing a larger blank "white space" on either side with no success. It seems that the centre (x axis) of the profile view grid seems fixed to the centre (x axis) of the viewport. Is there a way to either offset that or to maybe extend the profile view grid over the data bands?
James
JMWILSON87 wrote:
properties, styles and data bands they do not match.
Adding your border is just a start and the work has just begun.
First use the Import Styles tool to Import your Styles from your base drawing (it's sounding like those are
what you want the profile views to look like) into the Plan Production dwt.
Manage Tab of Ribbon>Import Styles & just import all styles into that Plan Production dwt.
Then go to Settings Tab of Toolspace and review & specify the Feature Settings and Command Settings
under the "View Frame Group" category. This is where you can specify things like the Profile View Style,
band styles etc. for the Sheets created. This is normally done in templates so it's available every
time a new dwg is created from the dwt.
This is where it starts to get deep and if your very new to Civil 3d or haven't done much of this it can be very confusing.
The Plan Production Viewport scale should also match the scale of the base drawing where your view frames.
have been created.
As you work through it ask more questions here.
Hi Jay,
Would like to try this out, but I believe 2010 does not have the import styles feature under the Manage Ribbon. I have checked in the CUI for this to add to the ribbon but no luck.
James
Oops sorry about that one, the command wasn't introduced until 2011.
