I have created a SW pipe network profile for the project I am working on. I have to show branch pipes from gulleys that connect to my main pipe runs i.e. into the manholes and saddles conenctions straight onto the main run pipes.
this is a pretty easy task for the branches into the manholes (please see attached image). using the structure style settings you can see a circle where additional pipes are entering the structure.
however I have a few issues when trying to show the branches into the main runs. I dont mind the visual aspect of it on the long section (branch pipes being shown coming down form the proposed surface and intersecting with the pipe) but i dont want the additional info it produces in the bands of the profile view.
as you can see in bands, additional information for these branch pipes has been inserted for pipe dia, pipe slope, invert level etc. I dont want to see this, just the info for the main runs. Any ideas?
Solved by MikeEvansUK. Go to Solution.
Two options.
use the split network command to change the pipes to a different network or use Ctrl + Select and select the label you do not want then delete key to remove it.
