Hi
I have just joined a new company, and using Civil 3D 2014. Doing anything is very slow, which really is not right, as its a good spec PC, better than my old employers, and theirs ran a lot faster. I am not sure about graphics cards, can someone have a look at the screenshot below and tell me if anything jumps out that looks like it could be causing an issue. It may be a network issue, but even when I save to my C: drive its having speed issues.
Thanks in advance
Big Maz,
When you say "slow", how slow are we talking? Have you tried opening a fresh, new, OOTB (Out of the box, not company) template drawing and checking the speed of things?
Dave
Dave Stoll
Las Vegas, Nevada
Are the files local or on a network drive?
That could be your problem, how does C3D react if you copy the files local? (just as a test). The fastest PC in the work is not going to help if your network is slow.
There are so many things and combinations of things that could make Civil 3D run slow. We've unconvered some of them, but I would bet there are more out there that we haven't even figured out.
Here is a list of what we check when C3D is running slow:
Drawing Variables
In the drawing or template file:
System Variables
Video card settings:
Properties Palette
These are the primary things we check when we see an issue with Civil 3D running slow. It's important to understand the effect of changing these settings before you change them, so I would suggest checking out the Help file if you're not familiar with the effects of changing any of these variables.
Hope some of this can help you narrow down the issue you're having.
