I have a user that can't edit a parts list that is in one of our drawings. Everyone else can. When he adds a part size to it, the diaolog box opens and it is just an empty form. Same thing if he tries to edit an existing part. He has this problem for every drawing he opens.
Thanks.
Solved by mstanek. Go to Solution.
Your users are probably not all pointing to the same part catalog. Run SetNetworkCatalog on the offending PC and point him to the working catalog.
John Mayo
If everyone is pointing to and editing the same catalog everything 'should' be fine...
Did he try partcatalogregen?
Can you confirm that this file and ALL of the parts contained in it were created with the same catalog you use now?
John Mayo
