troma
Message 11 of 12 (147 Views)
Re: Civil 3D model scale issue
12-11-2012 12:14 PM in reply to: AllenJessup
Can someone give a hand over here:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Z-distance-in-inches-not-feet/td-p/3732422#.UMeVCOQ72...
Similar problem I think, but I'm not familiar enough with imperial settings to be of much use.  The OP accidentally market it as solved when it isn't, so just a heads up that help is needed.
Thanks.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Neilw
Message 12 of 12 (141 Views)
12-11-2012 12:31 PM in reply to: troma
I took off the first "Solution" tag. Please check to see if it is fixed.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
