I have a storm drainage drawing that has all the parts, pipes, and their labels in model space (as a data reference) and everything shows up fine in Civil 3D 2010. But my drafter opened the drawing in regular 2010 auotcad with object enablers loaded and the labels were rotated to the world corordinate system and not the plan view. Is there a setting in the styles that controls this? Has anyone else had this problem?
Mike
Didn't get there, sir: would you please attach a couple of screenshots..?
This screenshot is the drawing in regular Autocad 2010. Notice the orientation of a few of the structure labels... I appreciate any help.
Mike
I've had this problem with 2012 and 2013 as well. I haven't found a solution. I think it is just one of those deficiencies we have to live with along with several other problems with exported files. Basically I find the export tools to be highly inadequate for creating printable finished documents due to the amount of cleanup work required.
There is a FIDELITY setting that you can play around with but it hasn't solved the problem for me.
