I am trying to place a Block on a Line so that I can drag it to different spots quickly, However when I change my Annotation scale; the block scales with it. How can I turn that piece off? (I understand with the text side of things). Or is there something else I need to use to get this to work?
thanks
Your title makes me think that maybe it is not a block, but a C3D label. If so, you can do it with a little work.
Make an expression in the label style family. It should look something like this:
0.6/{Drawing Scale Conversion}
where the 0.6 represents the size of the block (in metres or feet).
Give the expression a good name, and then set the size of the block to use the expression in the label style composer,
Mark Green
Working on Civil 3D in Canada
troma,
I tried your solution using a line label with a block inside it and it works like a charm. Brilliant expression.
Thanks Dan.
When I saw {Drawing Scale Conversion} originally I didn't know if I had to multiply or divide by or divide into, but a little testing figured it out.
Mark Green
