I am grading a road with grading objects from the create grading tools. I have it set to 12' @ 2.0%. From there i have a curb setup at the end of the road to be attached. (All of this works great).
However, I have a building pad with a feature line with grades intersecting the curb and the feature line (which represents a driveway edge of concrete).
When I look in 3D. it seems that the Curb is connecting to the feature lines previous elevation; and is not updating to the new curb elevation.
Another words, the curb line north and south of the intersection of the feature line is correct, but at the intersection; the curb line dips to the feature line elevation.
How can I get the feature lines to update to match to the curb line? Or do I need to move every feature line to the updated intersection?
Solved by troma. Go to Solution.
The picture isn't telling me much...but switching the style of the featurelines may help.
Have a look at Feature Line Site Properties in the help to understand. Then double-check that it is doing as you intended.
Mark Green
Working on Civil 3D in Canada
Mark Green
