Civil 3D Forum
Civil 3D - Grading Objects with Feature Lines
3 REPLIES 3
RCBmstg007
1895 Views, 3 Replies
I am grading a road with grading objects from the create grading tools. I have it set to 12' @ 2.0%. From there i have a curb setup at the end of the road to be attached. (All of this works great).
However, I have a building pad with a feature line with grades intersecting the curb and the feature line (which represents a driveway edge of concrete).
When I look in 3D. it seems that the Curb is connecting to the feature lines previous elevation; and is not updating to the new curb elevation.
Another words, the curb line north and south of the intersection of the feature line is correct, but at the intersection; the curb line dips to the feature line elevation.
How can I get the feature lines to update to match to the curb line? Or do I need to move every feature line to the updated intersection?
3 REPLIES 3
troma
in reply to: RCBmstg007
The picture isn't telling me much...but switching the style of the featurelines may help.
Have a look at Feature Line Site Properties in the help to understand.  Then double-check that it is doing as you intended.
Mark Green
Working on Civil 3D in Canada
RCBmstg007
Works Great!
troma
You're welcome!
Please be sure to mark a post as the Solution, if it solves your original problem. This helps others who are reading to find answers to their questions too.
Mark Green
Rail Community
