"miagear" wrote in message
news:13676027.1098800268453.JavaMail.jive@jiveforum1.autodesk.com...
> I've been working with the shipping version of Civil 3D 2005 and as I
feared, the grading is no more stable than the beta versions were. I can
crash the program almost at will.
> Try to copy a grading feature line = Crash
> Try editing the grading style to display slope lines after an instance is
in the drawing = Lockup.
Please submit bug reports (with data files if you can), so that we can
accurately reproduce the bug you are seeing and can fix those in the next
release/version.
> Try creating a 3D polyline (feature object) and see how limited the
functions are.
> How about filleting a grading feature line?
> Try sharing something as basic as alignment data from drawing to drawing
without out ridiculous work arounds.
> And YES the shift to CAiCE road design is a great step but, what about
things like intersections, Cul-de-sacs, eyebrows etc? Can't do it!
Some of these are workflow issues, and some might be enhancement requests.
If you have specific suggestions, it would be great if you could post each
one as a separate topic so others can also respond and attempt to work
through this.
BTW, I'm curious...were these bug reports/suggestions posted on the beta
forums?
> Here's a good one, create a proposed vertical alignment with vertical
curves and labels. Now, try simply moving the curve label....go
ahead....You can't do it!
Need details on this one. Please post a new thread. Thanks.
Himanshu
